dirtytorque
removing handbrake cable from rear caliper.
You can loosen the handbrake cables at the end of the handbrake lever in the car, this will give you about another inch of play of you dont completely undo it. there is no way i could have attached my handbrake cables on the Vr without getting some more slack and then it only just reattached. Hope it all goes well.
