endor71 0 Posted March 12, 2003 Batteries keep dying in my Corrado. I run a fairly decent sized stereo system in my car. Could the problem be an alternator charging problem? What ampage is a standard alternator on a G60? Should I get a 90 amp one from GSF? or is there bigger? :shock: Quote Share this post Link to post Share on other sites
Jim 1 Posted March 12, 2003 What kind of battery do you have fitted on your C? After a load of problems in the winter with my cheapo battery dying, I invested in a 56AH (I think) Bosch Silver from GSF (http://www.gsfcarparts.com) and it never let me down in the time I had it. Quote Share this post Link to post Share on other sites
146 Jockey 0 Posted March 12, 2003 endor71, Don't know if this will help, but I had a problem with my battery running flat all the time. Tried everything from reconditioning the alternator checking boot light etc. In the end I found it to be the Central locking. I had an alarm put in by a 'friend of a friend' and what ever he did f!£$%d up the electrics. Hope this helps. Quote Share this post Link to post Share on other sites
endor71 0 Posted March 12, 2003 Taking car to bosch car electrics specialist hopefully all will be fixed Quote Share this post Link to post Share on other sites
G60Jet 1 Posted March 12, 2003 Taking car to bosch car electrics specialist hopefully all will be fixed Have you checked your alernator brushes? i've just changed mine that wear worn out at just over 100k (miles = 150km) Quote Share this post Link to post Share on other sites
endor71 0 Posted March 12, 2003 Standard alternator is 65amp Mine works ok the battery is ok but.. My stereo takes upto 30 amps so.. I need a 90 amp rated alternator :twisted: Quote Share this post Link to post Share on other sites
