borders16v 0 Posted March 11, 2010 Any ideas on this guys. News pads and discs fitted all looks good but the Abs light came on. It must know the MOT`s coming :shrug: Are the sensors mega sensitive to jolts when fitting discs or is it something else,cant be a coicidence as light hasnt been a problem since it came on 1 hour before its mot 2 years ago,fecking uncanny. Cheers. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted March 11, 2010 It will be the sensors mate (or maybe just one of em) so 1st job is to get it VAG-comed and see which one. Then buy a new one, remove the old one and give the hole a GOOD clean in order to make the new item slot in easily. Its a bit of a tight fit so the key is to prep 8) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 11, 2010 If it was rear discs did the ABS cages get changed for new ones or were the old ones re-used? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted March 11, 2010 Even the fronts have cages dont they? Did you actually put an ABS cage onto the discs or did you not think of fititng the new discs with a new/old cage, as the discs dont come with them. I did this :oops: Quote Share this post Link to post Share on other sites
delfinis38 1 Posted March 11, 2010 if you don't have vagcom just check the resitance with a multimetre across the sensor ! the one with minimal resistance is the iffy one. Quote Share this post Link to post Share on other sites
millerman 0 Posted March 11, 2010 Even the fronts have cages dont they? Did you actually put an ABS cage onto the discs or did you not think of fititng the new discs with a new/old cage, as the discs dont come with them. I did this :oops: erm yes but its attached to the hub not the disk !! Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted March 11, 2010 Even the fronts have cages dont they? Did you actually put an ABS cage onto the discs or did you not think of fititng the new discs with a new/old cage, as the discs dont come with them. I did this :oops: erm yes but its attached to the hub not the disk !! ah :salute: Quote Share this post Link to post Share on other sites
RaddoMan 0 Posted March 11, 2010 new ones are 6 pounds each Quote Share this post Link to post Share on other sites
borders16v 0 Posted March 11, 2010 Cheers for the replies gents. It was the front ones that were done. I hate paying for the vagcom,seems a bloody ripoff. LIKE THE IDEA OF CHECKING USING MULTIMETER. New sensors 15£ a go and vagcom from hazy memory last time was 30quid. Will now wait till the mot to do work as no doubt there will be some other little surprises awaiting my rado and wallet :salute: Quote Share this post Link to post Share on other sites
