Reggit
oil warning light with oil gauge fitted
I'm just fitted an OEM oil/volt gauge, and fitted it following a guide on here.
Essentially, I've removed the dash light sender and replaced it with a dual pole sender, wired gauge to one pole and the dash light to the other.
However now the dash light is flashing at idle with a warm engine. There's nothing wrong with the oil pressure - it's just below 2 bar, some something amiss with the wiring.
I'm looking to get this working correctly, will i need to use a t-piece but would rather not if possible. How have others wired their oil pressure gauge senders to retain the dash warning light?
