pookyvr6
Going lower
Recently, I put Eibach springs and Bilstein dampers on my VR.
Though happy with the ride, I fancy taking a bit more off the height. I think the Eibach's lower 30mm so I fancy going a further 10-15mm (40-45mm in total). Anyone running a similar set-up? Any ideas on what springs to get would be useful.
Also, the front seems to sit a bit higher that the rear. Wierd. Should I have done anything else (i.e. bumpstops) when replacing (bushes and top mounts were done)?
Cheers
at the moment my front spoiler is 3 inches off the ground,dont think i could go any lower unless i completely avoid any speed ramps
A friend who had a Corrado VR6 before me initially fitted Koni shocks with Eibach springs to his car. When he decided to go a bit lower and fitted FK Konigsport Coilovers, not only did he have full height adjustment and adjustable shocks the handling capabilities were vastly improved. He raved about them constantly. I have bought a set on his recomendation. 8)
