fla
front bump stops - how tight?
I've got some Poly front bump stops for my car although fitting them, they dont seem to slide on to the shocks as easily as the regular bump stops. Is this just a property of the Poly? I assumed that they should be a loose fit? Perhaps the polyurethane needs to be heated up a little?
New standard bump stops were tight to get onto the shocks, not loose at all. Im guess what you've got with the poly bump stop is as they should be. Though i used poly exhaust hangers and had to use a drill to get them to go onto the exhaust hangers. So maybe its a common thing with their products. Couldnt you just drill the hole larger IF they really are too hard to get on (queue the Toad now that ive just said that :lol: )
dont think i've got a drill bit the size of the bore of the bump stops tbh. What is it - perhaps 20mm or so? I've just ordered a new set of originals although i'll have a go with the polys again.
