MArrado
Coil Pack Qustion
will a dodgy coil pack work better/apparently perfectly once the engine is up to temperature? trying to eliminate this from my lumpy running checklist.
Thanks,
Max
It might!
If it's cracked and moisture is getting to on of the coils, it may be shorting out. When the engine warms up and the moisture evaporates there's no more short.
Test is with a plant mister type spray at night ant see if you get a nice display of errant sparks.
