Fanjita
Window trim (top of door card)
Hi all,
I've had an ongoing problem with the bit of trim at the top of the door card that sits against the inside of the window. Firstly we removed a set from a scrapped Corrado only to find that they too, like mine, are broken. In an attempt to fit the least damaged one while I try to locate some non damaged ones, I can't seem to get it to fit right. It just keeps catching and getting pulled up by the window, I must have fitted it wrong, unless I have inadvertently tried to fit an early to a late?
Does anyone have any info on how these inserts should be fitted, and also where I might be able to find both a drivers and passengers one that isnt split.
Thanks,
Jim
Have you tried the dealers mate? You may find they're still available??
Went in on Tuesday, no luck, discontinued.
The bloke at the desk gave me a few numbers to try of dealers that have been listed as having a few left in stock, so all may not be lost. Looked like they were £16 + VAT each so I'll give them a try. If not its the scrappy unfortunately :( go find a C looking sorry for itself.
Jim
Jim
Bummer. :( Good luck with the search mate! One'll turn up!
I got the drivers side last week at my local scrappy for £5!!!
I'm off there again om monday, I'll have a look if you like, which side do you need?
