vagingit.co.uk
g lader removal problems
Im trying to remove the g lader from my g60 engine (a spare in the garden awaiting a turbo and a mk2 jetta)
The problem is, I cant get the bugger out! Ive undone it all, and its loose and wobbly, but I cant seem to wiggle it out.
The pulley is still attached to the charger as I cant get it off (the nut is undone, but the pulley is on very tight)
I cant remove the charger bracket from the middle of the block, but this doesnt have to be removed does it?
Any tips, as Ive spent the last 2 hours struggling with the bugger! :nuts:
once tensioner is loose ,the alternator is off and all the screws are out that hold the charger to its bracket,just rock it and pull at the same time until it comes out.
You do not need to remove the charger bracket nor do you need to take the pulley off.
hth.
