bluslc 0 Posted November 28, 2002 Does any one know why on my corrado head lamp switch gets very hot or some one had similar problem ?? so far I have replaced two switches... :mad: Quote Share this post Link to post Share on other sites
Jon TDI 0 Posted November 28, 2002 Do you have high wattage bulbs fitted? If so then it is advisable to fit an uprated wiring loom. If not, then check the wiring, fuses,etc. The switch runs a little hot anyway, but if have replaced 2 switches then something is wrong. Quote Share this post Link to post Share on other sites
bluslc 0 Posted November 28, 2002 Do you have high wattage bulbs fitted? If so then it is advisable to fit an uprated wiring loom. If not, then check the wiring, fuses,etc. The switch runs a little hot anyway, but if have replaced 2 switches then something is wrong. thanks Jon as far as i am concern i have standerd bulbs. who sells uprated wiring loom in UK ?? Quote Share this post Link to post Share on other sites
VR6 0 Posted November 28, 2002 think trimsport do one - not too sure about the address - .co.uk i think tho. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted November 28, 2002 we can do you a wiring loom mate mail order if you want? but make shure this is the problem first? mind you the uprated loom will make the headlights alot better than they are on all std corrados. did you think anymore about selling your grill ? Quote Share this post Link to post Share on other sites
VR6 0 Posted November 28, 2002 what kind of price do the uprated looms go for vfunk? (of course with the forum discount applied :wink: ) Quote Share this post Link to post Share on other sites
W3RKD 0 Posted November 28, 2002 we can do them for £50 inc p&p - your 5% :mad: Quote Share this post Link to post Share on other sites
ross.taylor 0 Posted November 28, 2002 I have uprated bulbs on my 1.8 16V, I think they are 90/110w bulbs and I've never noticed "switch heat"! Don't know if this means anything, or I'm just being unobservant. Quote Share this post Link to post Share on other sites
bluslc 0 Posted November 28, 2002 we can do you a wiring loom mate mail order if you want? but make shure this is the problem first? mind you the uprated loom will make the headlights alot better than they are on all std corrados. did you think anymore about selling your grill ? let you know next week(GRILL)!! as you know i am on my way to essen... i will call you about wiring loom once i have done few checks .. thanks Quote Share this post Link to post Share on other sites
Rado16v 0 Posted November 30, 2002 How you doing Sukh? The headlight switch is quite a common problem on C's anyway as you propbably already know. You just may have been very unlucky :( Otherwise, yours would have originally come with US spec headlights (you think Euro headligts were bad!!) From memory it looks like yours have been upgraded to Euro, thing is you can't just drop in Euro headlights - the wirings different so it would have been modified. I'd get the wiring checked out first mate and definitely upgrade with the loom. Worth bearing in mind it may already have one when the conversion was done. HTH Amit Quote Share this post Link to post Share on other sites
