lil b 0 Posted April 9, 2010 alas when i thought all was fine i notice my 8v is weeping a little oil from the right corner of the head near the dizzi cap ... its not major leak (looks like ive spilt a little oil wen topping up) .. i was wondering if anyone else has had this problem? will it be ok if i leave it if i keep my eye on my oil level ?? i no the vr6's do weep at the left corner of the block .... any help would be really helpfull thanks bexs Quote Share this post Link to post Share on other sites
jack-gtir 0 Posted April 9, 2010 maybe the cam/distrabuter end seal ? :shrug: i know 16v's are bad for weaping there good luck hope you get it sorted - jack Quote Share this post Link to post Share on other sites
lil b 0 Posted April 9, 2010 no its the passenger side if your looking head on Quote Share this post Link to post Share on other sites
millerman 0 Posted April 9, 2010 is it under or around the dizzy if so you need a new seal couple of quid from the dealer but will need timeing done after ! Quote Share this post Link to post Share on other sites
Jim 2 Posted April 9, 2010 Sounds more like the rocker / valve cover.. not the head gasket. Not an uncommon problem at all.. and not expensive or time consuming to fix. It's just a question of a new gasket and a few hours undoing bits and putting them back again :) Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted April 9, 2010 maybe the cam/distrabuter end seal ? :shrug: i know 16v's are bad for weaping there good luck hope you get it sorted - jack I've got this problem but if its coming from the corner of the rocker cover then it's as Jim said, its easy to replace but a bit time consuming removing the manifolds Quote Share this post Link to post Share on other sites
Jim 2 Posted April 9, 2010 It's not too bad on the 16v to be honest mate.. did mine with the help of Supercharged back in the summer before a show, and used it as a chance to fit nicely cleaned / sandblasted upper and lower inlet manifolds and a new rocker cover. Took a few hours tops and really isn't that many bolts, etc to remove :) The only fart is getting the lower part of the manifold up if you're not removing the injectors! With all the fuel lines connected, you don't have a lot of room to play with. Quote Share this post Link to post Share on other sites
lil b 0 Posted April 9, 2010 ive just had my valve gasket replaced its deff coming from the left corner were thr cylinder meets the block im 100% sure.. sorry just realised in my first post i put head .. but i mean were the head gasket is Quote Share this post Link to post Share on other sites
