krnau
early style switch diy
Hi all, in the unsuccessful search of an a.c. switch to match the early interior, I decided to do it myself. I'ts not finished yet, but I'll post some pictures anyway. However, if I get a mega :epicfail: , I reserve the rights of deleting this thread :lol:
Base switch
Corrado conversion V2 (3).pdfDSCN6830 (Medium).JPG[/attachment:fmpuu4uq]
my friend :lol:
passat climatronic wiring diags.pdfDSCN6837 (Medium).JPG[/attachment:fmpuu4uq]
drilling the switch, in order to remove the undesired icon
climatronic wiring-Golf from May 01.pdfDSCN6839 (Medium).JPG[/attachment:fmpuu4uq]
now removed 8)
2.8l 24v Climatronic system.pdfDSCN6840 (Medium).JPG[/attachment:fmpuu4uq]
finishing it
DSCN6841 (Medium).JPG[/attachment:fmpuu4uq]
done 8)
Corrado92.pdfDSCN6842 (Medium).JPG[/attachment:25rq5ecm]
it fits now! :D
2.8l 24v Climatronic system.pdfDSCN6845 (Medium).JPG[/attachment:25rq5ecm]
first light test!
DSCN6846 (Medium).JPG[/attachment:25rq5ecm]
the slice is getting painted now, with black paint. once the paint is dry, I'll remove some of it and leave A.C. "written" on it so it gets retro-illuminated. pics to follow :)
any opinions or thoughts are wellcome :)
In the end, I left the glue gun slice idea on one side, and I used a slice of white plastic instead :o
DSCN6904.JPG[/attachment:be4uijoh]
looks better than in this pics :lol:
Excellent work so far 8)
thanks :D I'll have to repaint the slice because a small piece of crap has fallen on it :bad-words:
The only issue i'd say is that if you're using glue gun glue the car gets hot enough inside to actually melt the glue, i know this because i used glue gun glue to hold the aftermarket tweeters in the original holders as the way they were originally stuck in failed (they were there before i got the car) and subsequently the car got hot enough for the glue to melt an they fell off...
Also if you're using standard bulbs to illuminate it (cant remember if the earlys used LEDS or not, i know the late does) then they too will probably get hot enough to melt the glue....
Just though i'd mention it! :salute:
thanks. I'm finally using a piece of plastic instead of the glue slice.
however I was thinking about glueing it into the switch with the gun glue but once I have read your post, I think I'll use "super glue". what else could I use instead?
early switches use bulbs but I'll drop a led in :)
thanks for your reply, it may have saved me of ruining my switch once installed in the car :clap:
hey, thanks. I have epoxy glue. would it be useful?
I think I'll better go to a scrap yard and get some a.c. switches from any car, then cut the section that has de picture and glue it to my switch. or print an a.c. picture on a plastic sheet or something like this...
well i have other things in mind before :lol:
