gengt_boy 0 Posted April 13, 2010 hi all, just wondered if anyone knows if a mk3 golf has the same front suspension setup as a corrado? regards lee Quote Share this post Link to post Share on other sites
G-Lad 0 Posted April 13, 2010 I think the short answer is no, but if you could elaborate on which model of corrado i think that would help. Id assume that a 1.8 16v would the same as a mk2 golf 16v, but im guessing. The corrado is a bit of a "missing link" between mk2 and mk3 golf evolution, from what ive seen.. :shrug: Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted April 13, 2010 Im running a 1.8 16V. I bought a 2nd hand coilover setup. Fitted fine Quote Share this post Link to post Share on other sites
yeti 0 Posted April 13, 2010 hi all, just wondered if anyone knows if a mk3 golf has the same front suspension setup as a corrado? regards lee Late model corrados have the same set up as mk3 gti's. Spring rates differ form 1.8/2.0 and the vr6 i dont know for sure on early C's. Quote Share this post Link to post Share on other sites
gengt_boy 0 Posted April 13, 2010 my car is a 93 2.0 16v, i have seen some uprated bushes and topmounts but they are for a mk3 golf, i just wanted to know if they would fit. cheers Quote Share this post Link to post Share on other sites
yeti 0 Posted April 13, 2010 my car is a 93 2.0 16v, i have seen some uprated bushes and topmounts but they are for a mk3 golf, i just wanted to know if they would fit. cheers most on here will agree that the best top mounts are mk3 vr6 ones, they can be fitted to all, they are longer lasting than pattern parts and made of a more dense compound than the ones for the valvers Quote Share this post Link to post Share on other sites
gengt_boy 0 Posted April 13, 2010 my car is a 93 2.0 16v, i have seen some uprated bushes and topmounts but they are for a mk3 golf, i just wanted to know if they would fit. cheers most on here will agree that the best top mounts are mk3 vr6 ones, they can be fitted to all, they are longer lasting than pattern parts and made of a more dense compound than the ones for the valvers thanks mate, should the bushes fit too?? Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted April 17, 2010 If you're going to fit the VR6 top mounts to a 16V or G60 you must also fit the VR6 or mk3 top spring platform as is different. The bearing in the VR6 top mount doesn't work with the 16V or G60 top spring platform. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 17, 2010 Yep - as above to use the separate bearing setup you must use the flat top upper spring plates - this is why coilovers require the later top mounts. Quote Share this post Link to post Share on other sites
