VR6_ROB 0 Posted April 17, 2010 video of it running I bought a raddo g60 beginning of march ran ok but i took the charger off sent it to g-werks to be rebuilt also had the smaller pulley and the chip fitted so the cars been in bits a while put it all back together today to try get her running i primed the charger and started her up runs really bad 1k revs and just dips constantly like a misfire it stinks of fuel and it started smoking slightly at the back of the engine what have I done?? I have double checked pipes and wires i took off are plugged back in not sure what to go for need it running for monday thanks rob Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 17, 2010 cant claim to be an expert but id assume the timing of the charger is out. seems to be fluctuating the revs in time with the noise from the bay.... id leave it off until you have a better answer than mine. Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted April 17, 2010 weird. All the vac pipes are back on the ecu right? Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted April 18, 2010 the vac pipe was not on the ecu runs pretty good now took it round the block and the end of the charger popped off bolt was loose holding it on took the threads with it strange I never fitted that bit put a longer bolt in seems ok for now just need to get some insurance so i can take it out on the roads Quote Share this post Link to post Share on other sites
