VR6_ROB
g60 runs bad help!!!
video of it running
I bought a raddo g60 beginning of march ran ok
but i took the charger off sent it to g-werks to be rebuilt
also had the smaller pulley and the chip fitted
so the cars been in bits a while
put it all back together today to try get her running
i primed the charger and started her up
runs really bad 1k revs and just dips constantly like a misfire
it stinks of fuel and it started smoking slightly at the back of the engine
what have I done?? I have double checked pipes and wires i took off are plugged back in
not sure what to go for need it running for monday
thanks
rob
cant claim to be an expert but id assume the timing of the charger is out.
seems to be fluctuating the revs in time with the noise from the bay.... id leave it off until you have a better answer than mine.
the vac pipe was not on the ecu runs pretty good now
took it round the block and the end of the charger popped off
bolt was loose holding it on took the threads with it strange I never fitted that bit
put a longer bolt in seems ok for now
just need to get some insurance so i can take it out on the roads
