Finners 0 Posted April 19, 2010 Hi, Does anyone have a picture of what a Supersprint Cat Bypass looks like for a corrado vr6? I'm not sure if mine has one fitted and its MOT time so you can see my problem. Dont want to go ripping it off it it is actually a normal cat i have Thanks Quote Share this post Link to post Share on other sites
Guest Posted April 19, 2010 if you have a bypass pipe it will be easy to tell, if the pipe from your manifold to your mid box is all the same size tubing then you dont have a cat a cat looks like a mini silencer box if you go on ebay or sumit and type them in im sure both will come up so you can see the difference the only problem you might have is if you have one of those fancy decats that look like a cat but again you will be able to tell the difference if you take a look on ebay hope this helps Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 19, 2010 The original SS ones looked like a normal cat so hard to tell without looking closely.... Quote Share this post Link to post Share on other sites
