mimjed 0 Posted April 20, 2010 idle has decided to sit at 1750 rpm again today. really getting on my tits. ive had a good grease up of throttle body and fitted and greased a new throttle cable just now. still no difference. the vac pipe to ecu seems fine. boost pipe onto throttle body was a little loose, have tightened but no difference. waiting for it to cool down and im going to give manifold bolts a tweak. have put a new isv on it and this solved the problem for a few weeks...... any ideas before i make use of the jerry can and a lighter?? Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 20, 2010 small pat on the back. seems one of the electrical connections on the throttle body was a bit loose. rammed it back in and all seems well for now :D Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 21, 2010 it seems that all is not well......again :pale: its quite stuttery to drive and seems down on power. makes lots of noise but doesnt reall go anywhere. idle now sits like this vac pipe had it? cant see any damage on it, but wont do any harm to replace. where to get a new one from? any other ideas? Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 21, 2010 nobody? :shrug: i cracked open the ecu while i was there and seem to be lacking a chip i was informed would be there. anybody shed any light on this? 21042010226.jpg[/attachment:1jrzgnz7] 2.8l 24v Climatronic system.pdf21042010227.jpg[/attachment:1jrzgnz7] Quote Share this post Link to post Share on other sites
