Stevie B
Cold air feed to airbox
Hi, i'm going to run a cold air feed from where the carbon canister was to my airbox on my g60. Just a couple of questions- how big should i make the hole in the airbox?
do i just drill a hole and enlarge it using a hacksaw? what do i use to bond the tube to the airbox? anyone got any pictures of this mod? Sorry if these questions are a bit simple, but i just want to do it right. Cheers. :D
hi steve you can use a sikoflex to bond the tube to the air box bond this in "hole cut to size of tube" the connect pipe to tube here and do same on the brake duct with the tube slashed to just poke through into the air duct ... the connect to this end too.
