plummer
Sticking Brake
Hi, just had my C in for its yearly test(NCT here in Ireland as opposed to the MOT) and it failed for 3 items, wheel alignment, sticking brake(passenger side front) and master cyclinder/servo sticking. The car drives without issue but you can hear a squek for the brakes when moving slowly. I had the car to the garage and they checked the capliper and said it was working correctly and that I should change the brake pipes before changing the cyclinder as that may be the issue. Anyone seen something similar?.
Thanks,
plummer.
Changing the brake line to the caliper appears to have done the trick, re-test happening Monday week so should know for sure if everything is sorted then. Of course the C presented another issue this morning, wouldn't start, looks like starter motor troubles.
