StormyTommy
ABS pump pipes
Ok Kip thanks for that, someone else had told me to the same but I was a bit skeptical that brake pipes wouldn't be held on in some way!
It's the low pressure side to the reservoir so doesn't need much. Even if it came off, your brakes would still work for a while.
