adolf1976 0 Posted May 20, 2010 just taken some bits off here and there to try and find the leaks. The water seems to be coming from the plastic joint on the bottom of water pump just below lower pipe. I am still changin the pump as this lower pipe has never been hot.anyone know what the plastic bit is called. The oil leak starts from below rocker cover goes thru manifold and on down to the sump .also there is a little amount of oil in spark plug tubes. So im guessin its the roker cvr gasket. Any opinions ? After taking a lot of bits off and being under and around car for a good few hours. I think its been stood up with thee idle prob and since developed the seized brake as a result. These fresh probs could arisen from it being driven again daily. Thanks for all your help guys you know your dubs. Scott Quote Share this post Link to post Share on other sites
