simo79 0 Posted May 23, 2010 howdy do folks. Managed to aquire girling twin pot callipers from a friend, they came off a 90 quattro. the callipers fit fine but the pads overlap the inside of the disk about four milimeteres. Pads dont appear to foul anything but i have concerns that it could become an issue as the pads wear down. Is there a fix for this either slightly narrower pads or a five stud disk with a slightly thicker pad area. Cheers simon Quote Share this post Link to post Share on other sites
VR6Joni 0 Posted May 23, 2010 Golf 288mm disks??? What carrier are you using? Quote Share this post Link to post Share on other sites
simo79 0 Posted May 23, 2010 Golf 288mm disks??? What carrier are you using?[/quot I got the carriers and pads with it, the only numbers i can find is 0135 if thats any use and 21736-3. Cheers for your input Quote Share this post Link to post Share on other sites
