badgerman
G60 front and rear engine mount replacement
Hi all,
Anyone knowledgeable in engine mount replacement on a G60? Mine are worn and the engine is moving a bit so before I fit my Eaton M90 I would like to replace them.
I need to know procedure, things to look out for, approximate time etc.
Any help would be appreciated.
Regards,
Chris
think all 4 cylinder cars are basically the same, might be harder to get at things one the front mount on a G60
essentially you just remove the mounting bolts and jack the engine up just enough to slip the mounts out
front and rear are fairly easy, gearbox mount can be a little difficult as the fixing bolts are slightly harder to get onto IIRC.
If all the bolts are easy to remove it shouldn't take much longer than 30 mins to 1 hr to do the lot.
