krnau
kr inlet manifold vacuum hoses quick Q
Hi there, I've replaced all vacuum pipes on my kr today. And, as usual, there are always some bad points in the corrado world :lol:
Could anyone tell me where goes each of both of the vacuum pipes that are attached to the angled bigger pipe that attaches to the Throttle Body?
There are two nipples there, one metal, one plastic; and there are two vacuum pipes, one of them connected to the air filter box' hot air flap.
Thanks!!
charcoal filter?
:shock:
it's a KR. are you refering to carbon canister? if so, kr doesn't have it.
I've had a look at vw factory repair manual and it's not clear enough :(
thank you !!
there is a valve on back of the air box I think. :shrug:
yep, that one connects directly to the main pipe. But what I need to know is about the two thin pipes attached just next to the TB :)
Do you have the rad cover panel? I think those hoses are on that diagram on the stickers?
not in mine :(:(
I have a diagram but it doesn't specify which nipple is for each pipe :(
IIRC one nipple was heat variying or something like this, excuse my poor English :lol:
that's what I have. but both nipples aren't oriented this way :(
thank you anyway!!
