krnau
MFA MPG X-FILES
Hi all,
All of a sudden, MPG started to show really "optimistic" values, so I directly suspected of a vacuum leak.
I decided to "delete" the vacuum pipe that's attached to the back of the cluster (early style cluster), so I unplugged it from the inlet manifold (it was attached to a t-fitting piece which I deleted) and connected the one that attaches to the ECU directly to the inlet manifold nipple, right.
NOW, the dash is getting no vacuum at all, so it should show either 0 or 99 mpg (min, or max, or whatever) as it has no signal.... BUT NO!! It's showing the correct MPG value now :| :| :| :| :| with the vacuum pipe disconnected.
How is it possible?¿!?¿!? I guess it's getting the MPG value from the ECU???
Let the experts come arround and give me some help,, please 8)
