Toby
VR6 Top mounts in G60
I've heard this is the thing to do, is it ?
Is it a straight swap - just the mount, or are other bits needed (Etka shows a bearing with the VR6 mount, but not the G60?)
I know it will apparently lift the front end up by about 10 mm - that will be a good thing !!
Cheers
Toby
VR6 Mounts consist of a rubber block and a seperate cartridge bearing. Interestingly VR6 mounts don't suffer from failed bearings like MK2 Golfs do but deformed rubber!
It doesn't lift the car 10mm as I fitted VR6 mounts to my Golf Mk2. They are the same height as the standard mounts. I'll get you the part numbers when I get home.
Do it, they last forever.
Kev
94 VR6
Yeah sorry, I forgot, here they are:-
Mounting - 357412331A - £14.30p
Bearing - 1J0412249 - £4.40p
You'll need two of each, total cost inc VAT = £43.94
Kev
94 VR6
Kev, are these the only bits that are required?
And would i be able to use any of the existing top mount parts like the top plate and securing nut?
cheers
Yeah sorry, you need the VR6 top plate aswell (forgot they're going on a G60) as G60ING pointed out. I don't have the part number for that I'm afraid.
Cheers
Kev
