merlin2002 0 Posted June 12, 2010 Hi guys Quick question, I jacked my corrado up today and notice I had up and down movement in the top mounts at the front? I assume this means my top mounts are shot can anyone confirm? Thanks Rob Quote Share this post Link to post Share on other sites
emu 0 Posted June 12, 2010 yep, new top mount's needed, or just tight the bolts up but you need new one anyway Quote Share this post Link to post Share on other sites
merlin2002 0 Posted June 12, 2010 thought as much, now to diagnose my other funny noises lol cheers Rob Quote Share this post Link to post Share on other sites
daleyboy 0 Posted June 13, 2010 I would check out other threads first do you know how old the top mounts are? When i jack my car up the top mounts move all over the place and my top mounts are about a year old, the gauge is where they sit when the cars on the deck. Quote Share this post Link to post Share on other sites
merlin2002 0 Posted June 13, 2010 I did have a nose at that thread But its like lots of movement, i can lift the hub up and the top plate will move up and down. im wondering if the guy before me fitted the coilovers wrong and forgot to install the nut on the top of the shock that holds the top hat on the springs. Im gona grab a couple of top mounts at some point and strip it down to have a looksy! Cheers Rob Quote Share this post Link to post Share on other sites
aide 0 Posted June 13, 2010 as above get them off to inspect, difficult to tell otherwise i changed the originals off mine yesterday - 93k and 17yrs - with new ones, and comparing side by side the only difference was about 10mm in depth and the centre hole was off centre, other than that they looked great, and you wouldn't spot when in position. does sound like your top nuts loose tho. Quote Share this post Link to post Share on other sites
daleyboy 0 Posted June 13, 2010 No with the car jacked up they do move all over the shop like i said look at the photo's in that thread to see how the top plate looks when the car is on the deck.......but they are cheap so if in doubt get some newens.............. Quote Share this post Link to post Share on other sites
