aide
Rear Fuel Lines
A bit of guidance please, can't find anything on search.
I plan to change the fuel lines at the back, but looking at the actual pipes and ETKA it seems a mangle of separate pipes and bits, in order we have;
tank supply nipple - rubber pipe - plastic pipe - rubber pipe - fuel filter - rubber pipe - plastic pipe to engine bay :cuckoo:
the return pipe is less complicated, just a rubber pipe from the pump and onto a plastic pipe upto the engine bay.
first question, do i need to drop the tank to replace these, or can i feed them through?
second question, what's best to replace with, bearing in mind my local dealer is very good at ordering the wrong parts, all original, a simple rubber from supply nipple all the way to the hard pipe half way (fixings?), or the same types but ordered from somewhere like pirtek the pipe fitters?
thoughts please :)
