nocrap
ABS Fault - VAG-COM Scanned
Hey, my ABS light has been flicking on and off for a little while now since changing my rear brakes.
I managed to scan it with vag-com today and it gave me this
VCDS-Lite Version: Release 1.0
Saturday, 17 July 2010, 10:58:18:0
Control Module Part Number: 1H0 907 379 D
Component and/or Version: ABS TEVES 04
Software Coding:
Work Shop Code:
3 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
35-00 - -
00293 - Multi-function Switch (F125)
16-00 - Signal Outside Specifications
00296 - Kick-Down Switch (F8)
04-00 - Mechanical Malfunction
The first is fairly self explanatory but I don't know about the other two.
any assistance would be much appreciated
Thanks
Weird codes there mate...
I would Re-Scan with Vagcom if you can and then clear them
Not sure I trust VCDS tbh - You've not got a kick down switch for a start being a manual!
VCDS-Lite is the updated version of 4.09 so it should be fine.... i know a few codes are incorrect for example the aircon one on my golf.
i'll give it a clear and scan it again after a drive
