emu
KW V2 rear top mounts nut ??
I was finishing my suspension today and tried to fit rear top mounts cover. I had 2 nuts included with my suspension but need another 2 to fit top mount big washers or locks, whatever it's called.
Problem is that M10 nut is to small and M12 is to big. I need M11 which doesn't exist :cuckoo:
Tried metal shops and ebay and couldn't find anything.
Anybody can help ??
Try a Japanese motorbike specialist sometimes they use odd fixings otherwise just order from KW they are quite good with being able to supply components from their suspension kits
Yeah, only KW will be able to supply a new nut. They are good to deal with though. They even give you a new spring perch for free if yours are seized. Must be part of their anti-corrosion guarantee.
Thanks for help.
Just contacted KW to order them. I hop they will respond fast, as would like to finally drive a bit :)
