timmaaah 0 Posted July 26, 2010 As per title - the clutch was starting to slip when the car was taken off the. For the last couple of days I've been able to select a gear, but today the pedal went down to the floor and was really sluggish in coming back up. When fully depressed, I cannot select any gear. I've checked the cylinders and there are no leaks from either of them (the one near the brake fluid container and the one on top of the gear box) - I also took the slave cylinder off, and got the missus to press the clutch - the nobby bit that comes out the end and goes in the gear box comes out, and I can't stop it. There also *seems* to be a rhythmic ticking noise coming from the gear box. Any ideas? Ta Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted July 27, 2010 If you've got no leaks then the seals have prob gone in one of your clutch cylinders. Mine had shot seals in the master cylinder so i got that done and the slave done as well as a precaution. Quote Share this post Link to post Share on other sites
timmaaah 0 Posted July 28, 2010 If I start the car in gear, I can feel the clutch dragging, and there's 1 millimetre of movement before the clutch fully engages. If I take of the cylinder and strip it, will it be very apparent if a seal has gone? If a seal has gone, I take it that there is some fluid not being fully squashed, as it's going around the seals? How does the master come off? Does it just unbolt from the bulkhead in the engine bay and the pedal kind of comes through or something? Not stripped clutch cylinders before but I'm sure it can't be hard :shock: :) Thanks in advance Tim Quote Share this post Link to post Share on other sites
timmaaah 0 Posted July 28, 2010 Update - slightly removed the slave cylinder so I could see the arm inside. When my wife pressed the clutch down, the arm extends and retracts fully. Any ideas? Tim Quote Share this post Link to post Share on other sites
Slimg60 0 Posted July 28, 2010 Sounds like your clutch arm has cracked. I had exactly the same symptoms including the ticking. Quote Share this post Link to post Share on other sites
timmaaah 0 Posted July 28, 2010 OK - cheers, Going for a clutch change soon then I guess :( Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted July 29, 2010 Sounds like a faulty slave/master cylinder to me. Quote Share this post Link to post Share on other sites
