b9085 0 Posted August 6, 2010 I have had my ABS vag com'ed and it has come up with an error with both front and rear offside sensors. My first question is will it definately be the sensors, or could it be the cables or connections between the ecu and sensors. Second is, I have looked on GSF and ECP the seem to have a budget and mid and expensive. Anyone had any experience with the cheap ones? Any good? Or should I just stick to the most expensive? Cheers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 6, 2010 What were the actual errors first of all?? Did you clear the codes and re-scan after a drive? Quote Share this post Link to post Share on other sites
b9085 0 Posted August 6, 2010 I don't have a vag com, a garage did it for me, they told me front and rear offside sensors. I'm afraid they didn't give me the codes. He did clear them afterwards when I started the car again my light is on, so I'm pretty sure they are still there. The garage said they will scan it again for free, if the fault happens again. But I was planning on changing the sensors this weekend myself and then take it back Monday and get them scanned again to check they are OK. Quote Share this post Link to post Share on other sites
