g60alli
Poosible Water Pump Leak
Hello there,
I've had an major coolant leak for a while, making my corrado un-usable. But considering i have a bit of time i wanted to try and solve this problem.
I think the leak is from the water pump.
(wet part)
Could anyone tell me what part needs replacing here to rectify this.
Cheers.
The thing in the picture is the PAS pump but if it's coolant then it must be dripping from above.
Water pump is £25 exchange from VW but on a G60 you have to remove the charger and bracket to get to it so worth while getting the charger serviced at the same time.
It could be just the plastic thermostat housing that is leaking and you can get to this by removing the Pas pump and bracket if required
