corrado_sunderland
vacuum for brake servo on 1.8t
my rado has abs and ive guttted all the vacuum piping out and dont know where to get my vacuum from for servo :confused4: does the servo have a feed coming off it as i cant see it and need to get a pipe to it from inlet :eek:
you take the vacuum off the pipe under the manifold...?
its got the feed on the inlet on the side but the g60 piping seems to have took the vacuum from somewhere else and i cant see amongst all the abs set up when to take a vacuum pipe too since all the pipes from g60 set-up now taken out as it had pipes all over the bulkhead :confused4:
