andy 0 Posted September 4, 2010 Is it important to only do the wishbone bolts up tight once the vehicle is back on the ground, i.e. normal wishbone position, or does it not matter. I can see that the rear wishbone bush wouldn't really matter as the subframe clamps the bush inner sleeve but what about the front one, Logic says leave it till the vehicle is on its wheels again, however its awkward to get to them then, what with the engine needing jacking etc. Quote Share this post Link to post Share on other sites
