vagingit.co.uk 0 Posted September 4, 2010 We have a standard G60, that 8k ago had a standard charger rebuild. what I want to know is, is it possible to just fit a chip, or do you HAVE to change the pulley too for more boost? would it be ok to run more boost through a standard charger? was thinking a 68mm pulley, so not too small also, who would you recommend for the chip, Jabba, Gwerks, or Ive heard good things about SNS chips? Quote Share this post Link to post Share on other sites
DanVW 0 Posted September 5, 2010 You have to have the smaller pulley to get more boost, all the chip does is adjust the maps feed to the ECU to take advantage of the extra boost the smaller pulley supplies, if you go SNS you also get their 'anti-lag' code which makes for a snappier throttle response, don't forget you will need a a smaller belt to go with the pulley, fit and enjoy! 8) Quote Share this post Link to post Share on other sites
