James_tulley
Cold bottom rad hose
From what i understand if the bottom coolant pipe remains cold then the thermostat isnt opening, and therefore isnt allowing water to pass through the radiator. The thermo should open at around 87deg i believe.
VW main dealer would be the best place for replacement parts
Yup and may also be worth changing the housing as this can become brittle with age. Also maybe worth changing the coolant sensor whilst you're doing the housing and stat.
Dont forget to test the new thermostat before fitting just to save you hassle of removing it again if it is fault (doubtful it will be but always check).
