woodman
Strange Plastic Isolator Clip Near The Starter Motor (VR6)
Hi Everyone..... After lots of "lurking" I'm afraid I've got to ask a Nooob question!!
Had My VR6 for about 2 weeks now and run into a little problem....
I have narrowed it down to an arcing issue inside a plastic clip type arrangement attached to the starter motor - now I'm sorry to ask but I don't know if this clip arrangement is a stock item or is an after market jobbie fitted by one of the previous owners!! - can anyone help me??
Took me a while to work out what was happening..... so far I have replaced the 109 relay & new ignition switch - Turns out this strange clip thingy I have found seems to be isolating a cable & stops it from arcing across and causing the starter solenoid from going into a spasm!!
Anyone else come across this issue??
Ok..... I'm an eedjut!!
It was the main power supply to the starter that was loose - all fixed now and no problems!!
Doh!!
