adolf1976 0 Posted October 9, 2010 the fuel pump casing is leaking from the top, around the two hose connections, have renewed pipes but still leaking. could it be cracked? it looks like the plastic is bubbly and brittle Quote Share this post Link to post Share on other sites
Wullie 1 Posted October 10, 2010 Dry the whole area, dust with talc and turn the ignition on till the pump primes. Now have a look to see if there any any "trails" through the talc which should point you in the direction of any leaks. If nothing shows try running the car for a few minutes, just to get some fuel flowing through the system and re-inspect. Quote Share this post Link to post Share on other sites
