Neil L.
Blown head gasket on VR6?
My VR6 been running quite rough from start-up (until it warms up!) recently i.e. cold damp weather! On the way home from work tonight the engine cut out - on re-starting the engine there was a significant loud burbling sound from the exhaust - as if the exhaust had blown! This continued for the half a mile journey to my house - there was also a big loss of power from the engine! There is mayo on the filler cap but nothing on the dip stick - coolant level seems fine albeit checking with a torch - i can have a better look tomorrow in daylight!
Not sure if these signs suggest head gasket or exhaust failure?
Mine went without any mayo in the oil or fillercap just oil in the expansion tank. Get a compression test done first but it sounds like you have a new kettle to me.
Not so!!! Ignition coil at fault - huge crack on the underside of terminal 1! Replaced myself this afternoon - goes like a dream again!!! :D :D :D
