titch 0 Posted November 3, 2010 Help? i have a 1.8 16v rado on k-jet that has gone completely flat, it wont rev from cold( and i mean it will not go above 1000rpm), when its warm its not much better, jumpy wilst driving steady, back fire from the exhaust from time to time. less than 15mpg i have replaced the fuel filter, fuel distributor, 5th injector, thermo time switch, all temp sensors, ecu, coil and module. i've checked the cam timing and for air leaks , adjusted the ign timing and adjusted the CO to 2% im thinking ist to do with fuel pressure? can anyone help. please? :confused4: Quote Share this post Link to post Share on other sites
dannyboy 0 Posted November 4, 2010 sounds like your dizzy timing is out a bit,how did you check the ign timing? Quote Share this post Link to post Share on other sites
pumbaa 0 Posted November 4, 2010 Sounds like timing or possibly dodgy injectors, can cause a plethora of undiagnosable problems! Quote Share this post Link to post Share on other sites
carrots 1 Posted November 4, 2010 did you sort it Quote Share this post Link to post Share on other sites
titch 0 Posted November 6, 2010 found the problem :( crank pully and fly wheel timing marks not lineing up crank shaft pully key way has collapesed and the pully moving back and to causeing it to line up then retard the cams by about three teeth. how was it still running and not bend valves? :scratch: lol Quote Share this post Link to post Share on other sites
