krnau 0 Posted November 8, 2010 This broke on my corrado yesterday. It's moving freely through the shaft :? what's it supposed to be? a counterweight? is it very expensive? :? :? :? thanks Quote Share this post Link to post Share on other sites
VR6 0 Posted November 8, 2010 I wasn't aware it was orange but if it's what I'm thinking of, it should just be a vibration damper. If so, most people just remove them if they're loose and causing a problem. Quote Share this post Link to post Share on other sites
krnau 0 Posted November 8, 2010 Is it worth fitting a new one? I have to replace a cv boot anyway... Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 8, 2010 if your driveshaft is rusty and/or the paint damaged a new one won't stick in place properly anyway, they have to be fitted at a very specific position but it doesn't seem to cause a problem if you run without one, so as above, just ditch it :) Quote Share this post Link to post Share on other sites
n3p 3 Posted November 8, 2010 I removed mine....but it didn't go without a fight :bad-words: p.s. :norty: Quote Share this post Link to post Share on other sites
krnau 0 Posted November 8, 2010 I removed mine....but it didn't go without a fight :bad-words: p.s. :norty: I'll fit a new one if it's not expensive. p.s. :norty: :norty: Quote Share this post Link to post Share on other sites
n3p 3 Posted November 8, 2010 I removed mine....but it didn't go without a fight :bad-words: p.s. :norty: I'll fit a new one if it's not expensive. p.s. :norty: :norty: Sounds like it'd be an arse to get it in place....mine made no difference without it anyway! Good luck though, I know you have the power :luvlove: :norty: :norty: Quote Share this post Link to post Share on other sites
