delfinis38 1 Posted November 9, 2010 hi guys i've done a seach and asked the Q before. but not really found the right answer. whats the difference between fuel filters with 021115562 and 021115561 parts numbers.... i've always used 021115562 but been offered 5561. is it okay to use ? TIA Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 9, 2010 Hmmm - Who's offered you the alternative as it's wrong?? There is only one Oil filter for the Corrado VR6 unless the filter housing has been changed to the later ODB2 Golf one. The correct part number for the kit is 021115562, I bought 2 last week for Jim from TPS and they are £6.40 each This kit contains the element 021115561A but you can't order that seperatly. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted November 9, 2010 Thank You. it was a stealer but thought he may be wrong approx £12 each. I'll stick to a 562 which I've always used. sounds like i need a tps account or know someone with one as I'm after a silencer soon. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 9, 2010 Hmmm - Who's offered you the alternative as it's wrong?? There is only one Oil filter for the Corrado VR6 unless the filter housing has been changed to the later ODB2 Golf one. The correct part number for the kit is 021115562, I bought 2 last week for Jim from TPS and they are £6.40 each This kit contains the element 021115561A but you can't order that seperatly. This link shows the correct part and the MANN part number (Genuine ones are made by Hengst) http://www.vwspares.co.uk/product_info. ... cts_id=193 Quote Share this post Link to post Share on other sites
delfinis38 1 Posted November 9, 2010 Thank You. Quote Share this post Link to post Share on other sites
