CorradoVR6-Turbo 0 Posted November 14, 2010 it looks like a fracture but its arcing across the top of the plug to the base...do you have these? Quote Share this post Link to post Share on other sites
raddo-dave 0 Posted November 14, 2010 yes on all 6 plugs Quote Share this post Link to post Share on other sites
raddo-dave 0 Posted November 14, 2010 sorry there is no marks on the ceramic only on the metal tips that go inside the lead Quote Share this post Link to post Share on other sites
raddo-dave 0 Posted November 14, 2010 is there any chance it could be a sensor? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted November 14, 2010 its difficult to say without being there and experiencing the fault,it sounds like a spark issue,or as mentioned before possible map fault,have you had vag com on it? Quote Share this post Link to post Share on other sites
raddo-dave 0 Posted November 14, 2010 no i aint had it on vag com yet, i have just bought the cable for it and my mates gonna come round with his laptop when i get it out of curiosity how would a map fault occur from transfering the charger set up from 1 engine to another? thanks dave Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 15, 2010 I never tried it with the VR6, but VAG-COM has output tests. When your mate comes round with his Laptop, install VCDS on it (www.ross-tech.com) and go into the Engine settings. If output tests for the VR6 are are available, you can check all 6 plugs are firing and also check all 6 injector drivers are firing. If you can test these, pull the fuel pump relay before cranking it over (167 in the fuseboard). Or you can do it the old fashioned way. Remove all 6 plugs and pull the connectors off all 6 injectors. Place a plug in one of the HT leads and rest the threads on a metal part of the engine, crank it over and look for a spark. Repeat for the other 5 plugs and leads. Or, if you can rest 6 plugs at once on the engine somehow, you can do it one hit. We can at least then outrule plugs, leads and the Coilpack. Checking injectors is trickier. There needs to be 12-16 ohms load across the injector plug or the ECU output won't fire, so you can simulate the load with a test light. A 12V 10 watt bulb will give you 14 ohms and connect that to each injector and crank it over. Then we can outrule the injector wiring. If that all looks as it should, it's time to call Stealth Racing I think! Quote Share this post Link to post Share on other sites
raddo-dave 0 Posted November 15, 2010 thanks for your reply kev, i was doing as u suggested,took the manifold off to get to everything and i noticed 1 of the injector plugs wasnt on properly(the metal retaining clip was off on the underside) so i put it back on and checked the others and it runs sweet as a nut now and has put a massive smile on my face i feel a right penis for not stripping it all back in the first place :mad2: thanks for everyones input much appreciated thanks dave Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 15, 2010 No worries, we all do things like that mate :D Actually, just after I suggested the injector checks I remembered you have the standard inlet manifold, so what a ball ache! Short runner intakes make things so much easier / quicker with forced fed VR6s :D Glad it's OK now! Quote Share this post Link to post Share on other sites
raddo-dave 0 Posted November 15, 2010 i have a short runner sat here in my room ready for my corrado which i was tempted to use when i was rebuilding the golf, wish i had,it would of made finding the problem very easy :lol: thanks again Quote Share this post Link to post Share on other sites
