16VG60 1 Posted November 22, 2010 Abdul - the exhaust follows the same route as OEM item but is built totally different. The 4 into one manifold terminates with an overbraided flexi joint, and three bolt triangular plate. The cat is deleted at the front part of the system, and continues from the manifold as a single component shaped pipe which includes an extended length straight through resonator section. The over beam pipe links into the tailbox, with has been contructed internally as a splitter silencer with twin exit. the pipe for the offside passes neatly between the spare wheel well and rear vallence. The systen is built from the largest bore pipe that could be used without clearance issues to therein improve extraction. Quote Share this post Link to post Share on other sites
K Simmonds 10 Posted May 9, 2012 (edited) Hey John, Thought I'd take a proper look at your 16VG60 build thread. That has got to be an awesome car to to track, lovely build. I'm so glad my my car came without a sunroof:cheers:. Be in touch very soon re charger-rebuild.:g60: My title refers to my Audi, not a VW!!! http://www.s2forum.com/forum/showthread.php?t=39279 Details here, and I've done a lot since the last update. Edited May 9, 2012 by K Simmonds spelling, as always! Quote Share this post Link to post Share on other sites
