jackvine 0 Posted December 7, 2010 Hi All Just stripped down my G Lader, have found one of the scrolls on the displacer is slightly damaged on the edge, also found that the apex seal and spring are missing from that one! Do I continue rebuilding it or try and locate another displacer ? The rest of the charger is in perfect condition. Quote Share this post Link to post Share on other sites
dannyboy 0 Posted December 7, 2010 that happened to one of mine, except the seal jammed the throttle wide open and went screaming down the road. :lol: Wasnt funny at the time though! :pale: that displacer can be repaired. i use something called E-metal(epoxy metal) its a chemical metal you mix that sets like metal and is quite strong and light. apply it ,let it set and use a dremel to shape the channels.or maybe you can get tig weld on it,not sure with the displacer(metal is alloy) Quote Share this post Link to post Share on other sites
jackvine 0 Posted December 7, 2010 Thanks, didn't think about liquid metal, will get some and give it a go ! How did you find removing the bearing oil seals ? Quote Share this post Link to post Share on other sites
dannyboy 0 Posted December 7, 2010 i just tore mine out cause it was pi$$ing oil anyway.just removed the circlip and pop,out they came Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted December 8, 2010 ..and if you want to do it properly you can buy seal removers. Quote Share this post Link to post Share on other sites
