pt_corrado
clean the G-lader internals
Hi there, just have one question.
How to clean the internal parts of the charger?
as the magnesium scroll is fragile, i like to know what products can i use to clean it, as in the moment there are to many oil inside of it.
regards
Hallo,
If there is a lot of oil in your charger it could probably use a refurb as it sounds like the oil seals are failing.
When was the last time you got it rebuilt or stripped down to check the seals etc?
Do not spray any cleaning fluid etc in the charger as it will damage the seals and potentially brick your charger.
Hallo,
i want to do a rebulit, but at this moment i just whant to clean the most of the parts. the oils seals are failing i know.
what kind of product can i use to clear the charger without damadging it?
I just use carb cleaner and loads of kitchen roll type rag and cottong buds for the akward bits. As long as you are replacing the seals etc and wipe all the excess out it should be fine.
