STORM 2 0 Posted December 23, 2010 Cold temperatures but never Battery in good shape 12.6V cold Fuel level low but not dry Accelerator pedal also very stiff Engine turns----doesn't fire Not the classic sound you get with fuelling problem or spark problem....thought it may be a frozen fuel line (but frozen petrol?????) Why the stiff acc pedal :scratch: :scratch: Quote Share this post Link to post Share on other sites
VR6 0 Posted December 23, 2010 Why the stiff acc pedal :scratch: :scratch: Arthritis in the knees? Quote Share this post Link to post Share on other sites
STORM 2 0 Posted December 23, 2010 Thanks Dr VR6 Quote Share this post Link to post Share on other sites
VR6 0 Posted December 23, 2010 :salute: More than welcome :grin: Quote Share this post Link to post Share on other sites
STORM 2 0 Posted December 23, 2010 Now if you can tell me where I can get a quick unicompartmental arthroplasty before Monday I will be impressed ;-) Quote Share this post Link to post Share on other sites
RW1 0 Posted December 23, 2010 It might be my old PC and how youtub works. It sounds like the starter motor is not engaged with the fly wheel. It is turning the engine? It will take a hell of a lot to freeze petrol..... how about -72'C give or take a few degrees depending on additives :D Throttle body has coolant in it. Whats your antifreeze level like. Up to strength of at least 40% additive???? Maybe the butterfly is jammed cos there is not enough antifreeze in the coolant and the water in the throttle body has iced and expanded. So jamming the throttle butterfly valve through distortion of the body??? . Quote Share this post Link to post Share on other sites
Reggit 0 Posted December 23, 2010 I'd agree with RW1 - sounds as though the starter motor isn't engaging with the flywheel. Quote Share this post Link to post Share on other sites
STORM 2 0 Posted December 23, 2010 Engine does turn - in fact it started up after a struggle... If the starter is not engaging with the flywheel then I presume that means the motor brushes are going? Quote Share this post Link to post Share on other sites
STORM 2 0 Posted December 23, 2010 RW1 - The throttle pedal was extremely stiff so that would fit in with your second diagnosis wouldn't it? Quote Share this post Link to post Share on other sites
RW1 0 Posted December 23, 2010 Engine does turn - in fact it started up after a struggle... If the starter is not engaging with the flywheel then I presume that means the motor brushes are going? Its not good sound for me but what I hear is a starter motor spining fast at some points. If so, it's the solenoid that is not heaving the motor spindle into the flywheel well enough. Before taking it ALL apart, disconnect the battery first. Then clean up the battery connection to the starter motor and then follow the battery earth lead from the battery down to where it connects below. Clean this connection up also. See if that improves the engagement. RW1 - The throttle pedal was extremely stiff so that would fit in with your second diagnosis wouldn't it? Only valid if your coolant is not to the proctective strength of 40% ish for these low temperatures. To test, pop a hand towel in hot water, pop it in a leak proof bag and rest that on top of the throttle body. Let it heat soak for 15 - 20mins. Then test the throttle to see if it frees up. I would refrain from pouring hot kettle water over it in this weather as the thermal shock may break the body or something else! If it does free up, hope the engine block is OK and increase the coolant anti-freeze strength as the next two nights are going to be bad ones for low temperatures. . Quote Share this post Link to post Share on other sites
STORM 2 0 Posted December 23, 2010 Many thanks RW1 - as always you don't fail to impress :salute: Quote Share this post Link to post Share on other sites
