Bobby
dodgy earth??
when turning on the ignition the dash lights seem to change in brightness from bright to very dull and continue to do this, so i'm thinking there is a dodgy earth somewhere. so where are the main earthing points on the corrado one inside and one on the gearbox? Thanks Bobby:D
Could also be the ignition switch, these are always failing. 20 quid from the stealers if it is that
