timg60 0 Posted January 14, 2011 As topic. am really in need if a set of linkages in gwo for the c as I can only now use her if there is no rain. It the first link from the wipers that has given in. Some times it stays on the ball joint sometimes it dosnt :? Am away for 2 weeks so replies will be sporadic but if you have some please let me know.. Tim Quote Share this post Link to post Share on other sites
8vMatt 1 Posted January 14, 2011 Will check for you tomorrow mate :) Quote Share this post Link to post Share on other sites
timg60 0 Posted January 14, 2011 Cheers fella Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 14, 2011 Tim, did you take the linkeage off the car when you put the linkeage back on the ball joint? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted January 14, 2011 Get a new one from VW, around £12 part number 536955325. simply push fits into place in about 30 seconds :salute: Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 14, 2011 Get a new one from VW, around £12 part number 536955325. simply push fits into place in about 30 seconds :salute: x2 actually. I got one mid last year when mine fell off in the middle of a rainy spell Never fitted it actually but cheap as chips. Quote Share this post Link to post Share on other sites
KIPVW 0 Posted January 14, 2011 Amazing how much better the wipers work too! no juddering or slopiness :) Quote Share this post Link to post Share on other sites
timg60 0 Posted January 14, 2011 vw in the morning then... Thank you Quote Share this post Link to post Share on other sites
KIPVW 0 Posted January 14, 2011 That is just for the drivers side though Tim, not sure about cost of the other side but i'm sure they'll advise :? Quote Share this post Link to post Share on other sites
8vMatt 1 Posted January 14, 2011 Get a new one from VW, around £12 part number 536955325. simply push fits into place in about 30 seconds :salute: Sounds like a better idea than me fighting to remove an old one, good shout. I might pick up a new one myself at that price :) Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 14, 2011 Matt unless the part is worn enough (which maybe useless anyway) to just be prised off you will just damage it to be honest, then it will be no use either. Quote Share this post Link to post Share on other sites
timg60 0 Posted January 15, 2011 It's the drivers side that has gone Kip. Will worry about the other side when that starts playing silly buggers as well. Tim Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
KIPVW 0 Posted January 15, 2011 Ah good stuff, make sure you put plenty of grease around the ball and plastic bush too! keeps it running smooth. I also uses some water pump pliers to push/squeeze it into place over the ball. Quote Share this post Link to post Share on other sites
